Results with the E3D using PLA is intermittent. Some people have issues I usually don't have issues with PLA. But I have to admit that before I change material I put a drop of sunflower oil on the filament before inserting it in the hotend and it is good to go for at least 12h printing. It might also depend on the kind of PLA I am using Colorfab which is quite tacky on the outside and it rubs on the side on the cooler.
And switching back from ABS to PLA make sure to do a couple of hot pulls to get all the ABS out since the lower print temperature of PLA can give issues if the is some ABS residual (same is true for colorfab XT as well).
I have printed quite a bit with V6 and PLA.
JO3 1
Thank you so much for your reply! Really helped out a lot.
I'm using the original thermocouple as I don't fancy changing the firmware.
Also thanks for the advice in using PLA, once I've got it set up I'll try printing with ABS and see how it goes.
