Thanks @IRobertI -- I'll take a bit of time and inspect the spool to see what happened.
Hoping it was a simple issue as you described.
Had a chance to remove the filament and inspect the spool -- had no issue with that but the slack in the bowden tube showed plenty of bite so it was definitely stuck at some point -- or it simply had a hard time rotating the spool -- going to have to set up a camera back there to see what is going on those long prints.
IRobertI 514
That is a severe case of underetrusion. And it looks like it happened quite suddenly which makes me think that something might have happened with the spool. Could it be as simple as the filament getting tangled on the spool?
