Thanks for your fast reply.
I'm using the sensor in an Olsson block as an upgrade (old sensor was impossible to get out without destroying it) so I will have to adjust temperatures anyway I guess.
Thanks again.
Thanks again.
Ha! It seems impossible when you are frustrated but iRoberti can take out 99 out of 100 of these things. He has magic, genius techniques. My technique involves WD-40, 150C heat and a sewing needle.
IRobertI 514
That is the PT100 that is installed on all UM2+ machines. It will work fine and it's an official part. You may have to adjust your temperatures slightly.
