If you print on blue tape, the print might stay stuck to the plate. Might, not sure. If you print PLA on bare glass, it will come loose when you stop heating the build plate.
If you use my "salt method" (=gently wipe the glass plate with salt water prior to printing PLA) then the print will stick like glue when the plate is hot: 60°C. But there will be absolutely no bonding at all when the plate is at room temp.
neotko 1,418
Bed heat has mainly the function of keeping the part 'stick' so turning it off might unstick the print. To keep the heat, for abs and materials that need a more stable temperature, make a door (youmagine has toons of examples). And, welcome to the forum
NilsfromGer 0
Okay, i´m printing with PLA. So better i leave it at that. Thank you for the answer :-)
