http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#shifted
Check if you have a loose pully. They really need to be super tight.
Thanks for the replies guys, I will check the pulley screws today. In the mean time a different 11 hour print came off the bed this morning, it was of a different, but similar part of the Inmoov arm. This part is of the same height as the one that experienced the layer shifting, but this one came out pretty good. Only thing I changed was infill to 80% through basic settings, I was previously using the 'quick print normal setting', which I don't know the infill % on that, but it definitely is less than 80%.
Overall, new print came out good, only real issue is the over hang has a "chewed up" appearance.
I have a single extrusion fan with shroud, 50m/s print speed, 210C nozzle temp. Any advice for improving the overhang?
I just realized the part with poor overhangs is luckily an anti-warping structure for printing in ABS (I used PLA, so next print I will remove it in Cura). However, still curious as to how to improve the overhangs.
Edited by GuestOkay, so I think I have ruled some things out. I was able to watch a print and saw the layer shift occur early in the print. So I know its not from the power flickering or from the stepper motors overheating. This is someone else's video, but this is exactly what I saw:
I assumed the belts needed tightened because to me they feel a little loose. I tried to tighten the screws, but they are already tightened to the max. I then moved the print head around while the printer was off and noticed it was quite stiff. Gave it some machine oil and now its moving much smoother. Not sure if this will resolve the layer shifting issue or not.
A video posted by Tom Saladerer mentioned that a good starting place for belt tension is to strum the belt and it should sound like an E Note from a Bass Guitar.
Is this an accurate test?
How do I know if my belts are loose?
neotko 1,415
You forgot the main one. Pulleys screws might not be as tight as they should. Check the 12 pulleys (motor pulleys included). If in doubt, mark pulley/shaft and print, as soon it slips check the painted marks to locate the slipping pulley.
