Posted · Cura 2.4 Beta not starting!
Unless you provide us with more information, there is little we can do to help. Did it generate log files? What is your operating system? Have you installed previous versions of Cura?
    Same problem with Cura on my side. ... CaJoDo
    I have installed a previous Version 15.04.x
    I noticed 2.4 is very sensitive to errors in machine setup. I changed the startup code of a custom machine and made a typo. Had one space in the start code on the wrong place. When I started cura did not just ignore that machine but started like a new install with no machine at all....
    After correction the custom machine .Json all was fine again :)
    Hi, I tried also version 2.3.1 with same problems. My english is not the best, how do you made a typo, and what is a typo? And a space in the start code? ??? Are you a (the) developer of cura???
    Lol no I'm definitely not a developer :)
    I made a misspelling in the file that defines the settings of the selected printer which caused that cura did not load any printer files at all.
