nice little update :-) I was curious actually how you were getting on with your new printer ?
Best wishes and good luck with the ultimaker :-)
Ian :-)
Ian :-)
This was a printer a friend of mine was leaning heavily into buying until he saw this review.
He went with the Solidoodle 3 and has had great luck with it
billdempsey 0
Just thought I'd pop on to give an update after 5 months of using the CubeX Trio. If I had to summarize in one sentence, I'd say, "the honeymoon is over." The printer is mechanically excellent, but the cartridge system completely ruins the ownership experience. It's not even the cost which is an issue (although that is one contributing factor for most people.) It's the reliability of the cartridges. I've tried a total of 8 different cartridges on my printer and every single cartridge has jammed at some point, usually ruining a long print in the process. In every case, I've had to cut the cartridge open, pull the filament out, and feed it from outside the printer. I figured they would fix this quickly. I was wrong. It's been 5 months and the only thing they did was make it even more difficult to use third-party filament. Now they check constantly during the print to make sure a valid cartridge is still inserted, then they write the remaining filament quantity back to the cartridge chip and stop printing when it hits zero. Even worse, after 5 months, the cartridges still suck. They've also been difficult to get due to ongoing supply problems. People have figured out how to use KISSlicer with the CubeX to get much better prints, but with the cartridges jamming constantly, it doesn't really matter. The printer is an ongoing pain in the azz. I'm considering keeping it for the mechanism and then gutting the electronics to turn it into an open source printer, otherwise you may see it on eBay in another month or two.
The bottom line: Until they abandon the cartridge system, I don't recommend buying this printer. Period.
I hope this advice helps somebody else avoid the frustration of owning one.
On a happier note, after I bought another bunch of replacement parts and swapped out a lot of stuff on my Ultimaker, it has been chugging away for a couple months now without any problems. I'm guessing this is the experience many others have had right out of the box. Better late than never, right?
