3DSystems is in the patenting and stiffening 3D printing business. They also advertise their budget FDM printers with SLS prints next to it. I personally wouldn't touch them with a long stick.
Your choice, I know you had a bad experience with the Ultimaker. And I hope you have a better one with the CubeX.
codemaven 0
I find it interesting that this only goes down to 125 micron and is not configurable beyond 3 settings (500, 250, and 125 micron). I normally always print at 80micron on my Ultimaker (default with NetFabb) and often go down to 40. Also, I'm really enjoying the Wood any Nylon filament options now which would not be possible on the CubeX. It will likely never get those - or the other options like PVA, flexible PLA, etc...
Also it seems that you have to 'activate' the machine. Not sure what that means exactly but it usually implies DRM. I wonder if they are brining DRM into the 3d printing fold. The software could potentially implement restrictions on what models you can print. I don't see much information on the software, but it apparently only works with stl files so it cannot handle .obj (which most current slices can) or AMF files (which are _supposed_ to be a new 'standard' format for 3d printing... though I've honestly never seen one). The software also only works on Windows so that eliminates all of the Mac and Linux users out there. I only use Linux these days.
Cheers,
Troy.
