Hi gr5,
Sorry for the delay replying. I found the setting in the menu and sorted it out quickly.
However after printing a part that should have had a circular section and it came out quite oval I found that the rod that passes through the print head on the x axis was about 3mm out of line from one end to the other! I assume this is what caused the switch not to line up in the first place.
I have now adjusted the machine to get this rod nice and parallel and then reset the position of the switch just to be safe.
Many thanks for your advice.
gr5 2,210
This is easy to fix - you can calibrate the location of where the switch goes into the core switcher thing.
It's in the menu system somewhere. It shouldn't be hard to find.
