However the prime tower is a common problem and cause of failures because it defaults in the back right corner and a lot of UM3s shipped with that corner lower than the others so it often falls over unless you fix your glass first.
So you think that the problem isn't the prime but the bed glass of the um3. Is there an official report I didn't saw about that @sandervg ?
1
gr5 2,210
That's called the prime tower aka wipe tower. You can enable visibility of that setting and then uncheck it. It is not mandatory. The idea is when one head is cooling a little filament oozes out over a few minutes and printing on the tower first leaves the little tube there.
However the prime tower is a common problem and cause of failures because it defaults in the back right corner and a lot of UM3s shipped with that corner lower than the others so it often falls over unless you fix your glass first. You can change the tower location but it prints faster there where the nozzle change is occurring. People who print without the prime tower are usually pleased with the results but you do get occasional holes where pva landed on a print and caused a tiny hole in the wall of the print.
prime or no prime - neither is perfect.
