To remove the print core make sure there is no filament in the "trumpet" (that top part of the core). Then let it cool completely. then lift a bit on the nozzle while you squeeze the finger things together (the black and clear tabs). And then pull out firmly.
If you are removing the right hand core I think it helps to lower it first but it probably doesn't matter.
SandervG 1,519
Hi Ivonna,
Thank you for your post. I'm sorry to hear you seem to have some difficulties with your print core. Could you perhaps illustrate your story with some photo's? Maybe that would make it easier to identify the exact problem.
Before it was stuck, how was your last print? Did your last print go fine?
Thank you for your time!
