Cura 2.3.0 seems to add supports properly, even scaled to 50%
In cura 15.X, in expert settings there are more settings for support - something about X/Y distance. Try setting that to zero or playing around with other settings. Or use cura 2.3. But really best is to design your own supports. It will save you filament and printing time.
ADM:
Please delete this post.
Edited by GuestADM:
gr5 1,967
Wow. Looks like a bug. Which version of cura is this? I'd play with the support features. Actually the crazy thing is every location it put support - it's not needed. The printer can "bridge" just fine from that center "tab" to the two side posts. At least from this angle it looks like it's not a problem.
And those 45 degree portions don't need any support either. Just the place where you point with the arrow - that needs support.
If you can't figure it out in support settings (set X/Y distance parameters to zero for a test?) then I'd just build support in CAD. Just put one support on each end of that tab before it switches to 45 degrees and turn off cura support.
RocketNut 1
Thanks for the quick response:)
I am using Cura 15.04.3.
You can down load the part at: DataLogger Support Frame
Please be aware the part is huge (W=54.4,D=39.8,H=247) and will not fit normal desktop prints, so you might have to scale it down for your printer. I have a Creality CR10 (CV-10 3D Printer), which is a large format (300,300,400) printer.
I will do as you suggested by adding the supports to the CAD file, and turn off Cura's support.
I do not understand what you are talking about:O
Again thanks for quick response.
Rocket Nut
Edited by GuestLink to post
