Thanks, and sorry for bothering - I will try this evening.
Did a Factory reset - now everything works - thanks!
1
- 1 year later...
It saved my life! @tinkergnome, you're the boss! I also did one "+" upgrade by myself (without heater - so I used TinkerGnome FW). Same issue, same fix:)
- 1 year later...
This (old) post also solved my very frustrating problem following a firmware update after replacing the hot end and having half the machine apart. I'd assumed I'd broken something, but after testing the switches was starting to fear I'd need a new mainboard. Factory reset did the trick.
Breathing a huge sigh of relief now. Thanks to @tinkergnome and the OP!
tinkergnome 846
Installing the recent original firmware corrupts some of the stored "tinker settings" (and vice versa).
Check (at least) the preferences for "Print area" (or make a factory reset to restore the defaults):
https://ultimaker.com/en/community/22363-help-upgraded-tinkergnome-firmware-now-i-get-x-or-y-switch-broken
