Tinker firmware - UM2+ Extended getting ER07 on home head with 16.12.1
markusmaker
Posted · Tinker firmware - UM2+ Extended getting ER07 on home head with 16.12.1
Hi there!
I immediately get a "ER07 Error Stopped X or Y switch broken" on home head.
With original firmware everything (including printing) works fine. Its a UM2 Extended which has been upgraded to Plus (by myself).
Before the printer was upgraded I used a older TinkerFirmware on it. I think it was 15.10.x.
I also tried 16.03.1 but same issue.
See
https://www.dropbox.com/s/v3h8kklk25viyux/originalfirmware.mp4?dl=0
and
https://www.dropbox.com/s/7qvtn6skva6c5eo/tinkerfirmware.mp4?dl=0
Anyone with the same issue?
    Installing the recent original firmware corrupts some of the stored "tinker settings" (and vice versa).
    Check (at least) the preferences for "Print area" (or make a factory reset to restore the defaults):
    https://ultimaker.com/en/community/22363-help-upgraded-tinkergnome-firmware-now-i-get-x-or-y-switch-broken
    • 1 year later...
    This (old) post also solved my very frustrating problem following a firmware update after replacing the hot end and having half the machine apart.  I'd assumed I'd broken something, but after testing the switches was starting to fear I'd need a new mainboard.  Factory reset did the trick.
    Breathing a huge sigh of relief now.  Thanks to @tinkergnome and the OP!
