Flexible Filament dont stick to build plate
OmegaCO
Posted · Flexible Filament dont stick to build plate
Hello,
I have a question :
I am trying to print a flexible phone case on my Ultimaker 2 Extended with Innoflex.
So... i have discovered that the flexible filament solve from the buildplate after some time. The edges bounce up and dont stick to the buildplate anymore. As I stopped the print i saw that the layer from the buildplate is very glossy and shiny...beautiful.
So, here is my question: Can I make the flexible filament stick to the buildplate (possibly without glue) ?
My bed temperatur is currently 60 ( maybe i should turn the bed temp up?)
I would be very thankful for a response!
Ps : (Please excuse any spelling mistakes, I am from Austria, dont judge me)
    Posted (edited) · Flexible Filament dont stick to build plate
    For flexibles I use hairspray on a paper towel with windowwasher, and use it to clean the glass. To remove it I put some drips of window washer and it leaves the glass without issues.
    Something like this
    More on
    https://ultimaker.com/en/community/33206-greentec-pla-easy-removal-after-hairspray
    Hey!
    Thanks for your quick reply
    One question: the "window washer" what is this? Is this the liquid you fill in the front of you car for the windshield wipers ? If yes, isnt this dangerous?
    you can use the same liquid you use to wash dishes (plates etc) will work
    I have found that the best improvement I made to my UM2 was to install a BondTech extruder feeder, after which flexible filament is very easy to print
    good luck
    Hey!
    Window washer, to clean home windows. It has isopropyl alcohol and other alcohol + perfume. The alcohol makes the surrounding areas drop temp faster due fast dissipation and the liquid breaks the hairspray pva bond. (That's at least my theory)
