I am using a Creality 3D® CR-10 (CV-10 printer) large format printer and Cura 2.3.1.
What plug in do I need to do the pause-at-Z setting? Is there a function that moves the print head to 0, like the Change Filament controller function does , so the print head is not in the way that could possibly throw off the head tracking off?
Labern 772
Yes. What printer are you using? what cura version are you using?
UM2 family printer you can go into tune and pause during the print.
there are also plugins that you can use called pause-at-z where you can set in cura a height where the printer will pause.
