SyntaxTerror 344
Problem with the extrusion upgrade kit is the price and what you get for it. It seems to me like you pay about €200 for the convenience. Perhaps a bit more. Which is fine if you like convenience of course.
A valid point, it is rather expensive. And the various feeder designs out there can certainly do wonders to improve the printer's reliability, there's no doubt about that. The feeder mechanism is definitely my main gripe with the UM2. Especially if you're trying to print something brittle (anyone tried bamboofill on a stock UM2? Dear lord, take me now).
Whether or not the extrusion upgrade kit is worth the money, I suppose is a matter of opinion. I will say that the geared feeder and the Olsson block are two things I can't do without on my printers. The geared feeder because it probably cut the total number of failed prints by two thirds for me. The Olsson block because of ease of operation and maintenance. Need speed? Huge nozzle goes in. Need detail? Tiny nozzle goes in. Clogged nozzle? Replace it in 60 seconds. I think I might have to make a shrine to mr. Olsson someday.
- 2
fbrc8-erin 283
Belts, motors, electronics, etc. should all still be in excellent shape.
Regarding the specific runtime stats, do you know if the PTFE coupler was ever replaced?
Depending on the materials you're working with, PTFE coupler replacement was usually recommended around 500-700 hours or so. The new TFM couplers last longer and are a more durable material, so if you see extrusion issues, that would be the first place I'd look at. Here's a photo of 1 good coupler and 2 bad ones; you can identify couplers that are wearing out by the presence of a lip, having a visibly widened out end near the heat, and discoloration (severe discoloration is most common if higher temp filament have been run).
I'm a fan of the Ultimaker 2, and still have one I run at home that I haven't put the upgrade kit on. I think as long as you're not asking too much of the feeder, it works well. If you're going to push it to higher speeds/more volumetric extrusion, you need to increase the temperature to compensate. I often run mine at 225-230, which is hotter than I usually run a UM2+ or a UM3 with the geared feeder. The UM2 feeder is designed to skip back if it can't meet what you're asking for in terms of extrusion, to try to avoid grinding down, so if you ask more than it can handle volumetrically, then you'll see under extrusion.
SyntaxTerror 344
You mentioned upgrading the feeder. If I were in your place, I'd give some serious consideration to the extrusion upgrade kit, getting your printer modified to the plus version. I know it's a serious bit of cash compared to the machine itself, but I'd do it in a heartbeat myself. The first printer I bought was a UM2. Time went by, I decided this 3D printing business was pretty damn handy, and bought myself a second printer which was a UM2+. I didn't own that for more than a week before I'd bought the upgrade kit for the UM2. The UM2+ feeder is just better by an order of magnitude. They don't even compare. Then add to that the ability to swap nozzles in mere moments. If I'd known how much more awesome the + version is, I'd have done it right from the start.
Just my opinion, of course.
jonatanrullman 17
Thanks.
Yes, the PTFE coupler would probably be a good thing to replace. Or at least buy one to have at hand.
I have not had trouble with the extruder at this point, only having done a few prints. But from the comments it sounds like it is not a bad idea to do something about it to avoid trouble that may or may not arise.
Doing a bit more research yesterday I think that I will give Medusa's belt driven "gearbox" a try with the original feeder. It's very cheap to build so I might as well just try it out and if it works then I can put the money towards other improvements. And if it doesn't work then I have only wasted €5 or so.
After a bit more research yesterday and today I am however pretty sure that I will do my own version of the upgrade kit because it does look like a nice set. I just think I can do it for about €150 instead of €500.
Cheers
