for the enclosure, check this: https://www.youmagine.com/designs/stand-holder-for-the-full-graphic-smart-controller
You won't loose any settings using my firmware, it is exactly the same as the Ultimaker one, except for the controller (unless you select any other fancy option )
amedee 349
This one should work: https://folgertech.com/collections/lcd-displays/products/lcd-display-controller-12864-graphical-reprap-ramps-3d-printer-mendel-1
It is a ReprapDiscount Full Graphic Smart Controller.
It will need a custom firmware (like this one https://bultimaker.bulles.eu
mechaneil 20
Thanks for the response. Although I was hoping to get something similar to the
original LCD's size so I still can use the Ulticontroller's parts/enclosure.
But it's also great to know that there's a good alternative that I can use. Just need to design and print a custom enclosure.
Thanks also for the firmware link. My UMO pretty much has the stock firmware AFAIK, but just to be safe, how can I find out it's current settings. Kinda new to this and threading very carefully, lest I make a mistake and ruin the board.
