Removing the Bowden Tube from the Head
jleichne
Posted · Removing the Bowden Tube from the Head
Hey!
So I want to remove the Bowden tube from the hot head so I can attach it to a new mount for a syringe-extrusion setup.
How do I go about pulling it out? Do I need heat? Do I need to hold down a little white thing like when you remove the bowden from the back extruder?
Thanks! I'm cautious about pulling too hard before asking the community.
Jared
    • 1 year later...
    • 1 year later...
