Posted · Weird zhop type movement in vase mode (Cura 2.4)
I'm running the latest version of Cura (2.4, not beta) and am having a weird issue when using vase mode. It seems to be doing a zhop type movement every layer, but is actually running in vase mode. You can see what I'm talking about in the video.
Anyone have any idea what setting might be enabled, or is it a bug. I'm using a 0.8mm nozzle on my Ultimaker 2 Extended +.
    This is weird, I see no reason why the seam is there. I loaded another vase into your project and the resulting .gcode has this same seam again in spiralize mode.
    5a3327a06b70f_ScreenShot2017-02-24at17_04_05.thumb.png.b80bf0604bd8a2b952abe11dcfa3cf5f.png
    No idea so far - sorry. Maybe someone else can chime in and help.
    @Nicolinux - what is that gcode preview software you are using?!
    Thanks.
    It is the one from Raise3D:
    https://www.raise3d.eu/pages/download
    This is a known issue that has reportedly been fixed for Cura 2.5
    It's not a bug i think. Had the same Problem. It is the "Retract at Layer Change" Option. Uncheck it and it should be gone (at least it solved it at my print). Maybe you have to search and activate the Option first in the Custom/Advanced Settings Window.
    You also need to set Outer Wall Wipe Distance to 0 otherwise that will cause z hop.
    BTW Cura 2.5 has a whole new spiralize implementation which does a better job of hiding the z-seam.
