Meaning of LED colors of rotation button
3dnerd
Posted (edited) · Meaning of LED colors of rotation button
today I printed something on my Ultimaker 2. I created a gcode file using Simpolify 3D.
After around 75 percent the Ultimaker stops and then the LED of the rotation wheel turned from light blue into green. In the past I printed several objects (also created with Simplify 3D) without any problems.
- Can someone tell me what this green color means?
- Are there other colors showing up - if yes what is the meaning of the other colors?
Thanks a lot!
    Posted · Meaning of LED colors of rotation button
    I have had my UM2 for three years, in that time I have never noticed any other colours than a greenish blue from the rotating control knob. I do not think that there is anything other than that colour, interested to hear other opinions though !!
    I bet I know what this is.
    The back of the button is a hole which is inside the printer, that allows filament to fall into the button housing and not only cause obstruction but get in the way of the leds.
    Has any filament fallen in?
    Push the button out using this hole from inside the machine, you'll be surprised how much is in there
    HI,
    my rotation wheel is printed by myself using transparent PLA.
    So the whole wheel turned into green - that cannot come from filament inside.
    The color really turned into green. My daughter was with me and asked me why it turns into green. So the green color was really there!
    Don't worry, there's nothing wrong with your visual perception. :)
    The led ring of the encoder wheel contains multicolor (RGB) leds. Fatal errors are usually indicated by a "glowing" color-change of the encoder wheel. Most likely all came to a halt while the color was green, but before the printer was able to write the exact error message on the screen.
