Cura and Custom Dual Extruder Printer
ManuelW
Posted · Cura and Custom Dual Extruder Printer
Why do you think you can't use it?
It's possible to modify machine settings in the .json file. It's possible to set reprap gcode. Some of use also use cura 2.4 on the beta Mark2 project (the Ultimaker2 with magnetic head changer). Did you try?
    Yes, i try'd a few days to get Cura with my CTC Dual working, but had no luck.
    I was searching in some boards for settings, but found no help.
    I saw a picture of a old version of Cura, where was Makerbot with Dual Extruder includet, but can't find this version.
    Most of slicers have the ability to use Dual Extrusion out of the box.
    I try'd again with the Ultimaker Dual settings, but had no luck to get ist work :(
    I can dropbox you my cura files (.json + extruders) for the mark2, so you have a starting point that produces dual reprap g-code. I'll try to remember to do it tonight :)
    Thanks a lot, that would be very nice :)
    Hi, is it possible for me to get that file?
    I just send you both a dropbox link, you'll obviously will need to change stuff, but I hope it will get you started.
