2 hours ago, ahoeben said:Heat up the hotend. Then remove the blue or red clip underneath the collet around the bowden tube at the hotend side. Then you can push down on the collet and gently pull on the bowden tube. The material will probably come out with it, and you can pull it from the bowdentube from the hotend-side of the tube. Then reinsert the bowden tube in the hotend and replace the clip.
hi,
i did try to remove the blue clip (in the image) and push the white collet (I think that is the collet u meant), but there I couldn't get any movement in the tube. Did I do something wrong and how can I fix the issue. I did pre heat it to 210°C and it's PLA 2 that is stuck inside the tube.
Edited by deedikjepijn
ahoeben 2,047
