Hardly know what I'm talking about but could it be of any help to check the bigbox profile in an online .json checker, just to find a potential syntax error ?
cura 2.4 bug - printer profiles dissapearing
there was no supplied profile, all i did was click "add new machine" then "add custom fdm" and give it a name. same thing ive done with all of our other machines and none other than this one have had issues
Think your best bet is to get a working profile from someone who also has a bigbox
In this case I guess e3d is the supplier... why not ask them... I hope they still provide some support?
yellowshark 153
Hi I think you guys have this wrong; @lance-greene says he is using a Custom profile. This does not use 3rd party contributions - that is when you select Other printer. With Custom printer you set it all up for your printer.
This is I suggest a CURA bug. I suffered it with 2.4 Beta and 2.4 Beta 2 - but I do not recall having seen it in 2.4 Release. Before I installed 2.4 Release I went to the Machine_instances folder and deleted every printer file just in case
nallath 1,125
Could be a lot of things. All non-um definitions & profiles are contributed by third parties, so the quality will vary. My best guess is that there is a issue with the provided profile(s) which causes the issue.
