Posted
· Printer head moving too far in X direction...
Did you use Cura to slice the robot? Did you go through the Cura wizard where you check limit switches (aka end stops)? Did Cura load the marlin firmware into the ultimaker? What version of Cura do you have?
Assuming you got through the above just fine...
Assuming you don't have an ulticontroller, and assuming you are using Cura connected through usb, click "print". Control the X axis and Y axis. positive values in X should move the print head to the right. POsitive Y values should move the head towards the back. Is the X motor backwards? Maybe the wires were soldered to the X motor backwards if it moves the wrong direction?
I believe if you wire the servos backwards they move the opposite direction. There's also a flip bit in Marlin somewhere to flip any of the steppers.
Posted
Sorry for not following up on this before. The x-motor was indeed attached in the wrong order. I have no idea how I had managed to get so far without noticing.
gr5 1,858
