my first thought would be to try lowering the print head temperature a little, then maybe increase the cooling fans a bit. but that is without any knowledge of your current settings so that may be not relevant ?
good luck
good luck
good luck
Currently printing at 220/60 @ 30mm/s. I might try lowering that to around 200 and test again. Fans are set to 100%, as I never mess with those settings. I also forgot to mention that this was PLA.
Before tuning the settings on your own, try the default printing profiles in Cura. A lot of effort has gone into these, and for most models these are hard to beat.
And use the newest Cura of course.
Edited by GuestBefore tuning the settings on your own, try the default printing profiles in Cura. A lot of effort has gone into these, and for most models these are hard to beat.
Thanks, tomnagel. I use the newest version of Cura, and I've tried the "default" settings for Cura on a few of my first prints, which were quite good. I've only recently been dabbling in the more advanced settings.
It's good to know that the default settings have been tuned quite well, and I will keep this in mind. However, sometimes you just want to be able to adjust things on a per-print basis due to model constraints ;-)
Melka 57
Yes, you are right !
Those are called Z-seam.
I'm not sure you can eliminate this artefact, but now you have the technical term to investigate![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
Edited by GuestLink to post
