The basic problem is that the part is wobbling while it's trying to print it. Because it's so thin. Can you instead print it flat on the print bed? With the rivets facing up? There is a rotate feature in cura - click on the part and choose the rotate icon and rotate it 90 degrees.
I don't know why it printed better before. Maybe if you slowed it WAY down to say 10mm/sec it won't wobble but it will look so much better if printed flat. Also you won't need brim if you print it flat.
gr5 2,172
catohagen 41
Yeah, lots of advantages in printing this flat, strenght and visual vise.
