kmanstudios 1,120
Well, I am designing each model for printing close to original size. The small, 14" and supersized. There will be playing room for either upsizing or downsizing each model. But I wanted to really give something that worked within the scales I am printing.
Each model is a lesson for me. How to make water tight (and no red in the x-ray), scale up and make interlocking parts. If yer gonna play, just play with something you love and have intimate knowledge of.
I've been fighting a severe sinus infection that has moved into my chest and I am a bit behind in posting the follow ups.
For instance, the 14" had a printing flaw. Not enough to do another 72 hour print, but I did make a fix and will use it in the other thread as a tut on how to 'fix things' using my experience as a kitbash modeler. For instance, I made a custom Batmobile from a '67 Corvette. We had the '60s version (still a classic), the '80s versions (Tim Burton) and I made it to fill the '70s when it was drawn to be a modified sports coupe. So, used to makikng do with things that are able to be fixed. Some weirdness happened with the printing in a few spots.
But it will be coming up as soon as I am not feeling like death warmed over. The printer has been working a lot. Thank goodness I ahve a backup of test models to print while I sleep.
And, I did a quick test of the nacelle to check the joining pegs and scoop placement. Got that nailed. And, yep, it did require supports. Fortunately, it can be done by model settings and speed things along.
SandervG 1,522
Looks good. How many of these buildplates will you need to print?
Did that overhang on the second tallest part have support? Looks like it might need it.
Sometimes when you scale up or down, margins used by the original designer become either too small or too big, and therefor perhaps a less strong model (think of that 3D printed wrench for example). But I don't think that matters for this model, does it?
