You could post your feature request on github.com/Ultimaker/Cura/issues.
Make sure you include why you want this feature, how it would improve Cura, and who would benefit from this feature.
Because what you call "priming" is not seen as priming by Cura. The 2 "custom prime towers" are not prime towers, but just regular objects. There is no way to tell Cura in what order objects must be printed.
Have you tried printing your object without primetowers (with the latest version of Cura)? In most situations, that works really well (if you use the provided printing profiles, and use Ultimaker materials).
Not so with polycarbonate. And PVA cannot be applied to PC, although PC can be applied to PVA. Here's a pic of what happens with my custom tower of PC. If I don't prime a sacrificial part, then this hairy mess happens on my good part.
@tomnagel is correct. And I want to use two custom prime towers in order to prime both nozzles but keep the material separate. The Cura-generated prime tower uses the same tower to prime both nozzles.
Thanks @ahoeben.
Silly me, I assume my brain did not register the word "custom" when I read it
I have not had that happen with my PC prints. Are you printing more than one object with PC at one time?
In this specific case, no, but usually yes. What do you mean by "that"... do you mean the prime tower isn't hairy like in the photo?
Any hairiness at all. With PC, I have experimented with Supports, but my main prints have been done without supports and therefore no priming tower.
When I do use priming towers, there is some gook around it as it is there to wipe off the crap before printing.
ahoeben 1,760
> Is it possible to force this as I require?
Not as far as I know.
engr 2
Since you are the only answer, you get the "Best Answer" vote. But how do I make this (forcing print order in Cura) a feature request? I don't see a feature request section of the forum.
