Thanks you for the response.
This solves the drift, but is under extrusion also common with this problem, or might this be a temperature / speed problem?
As you can see my speed is not that high, temp. is 210 C and using green Makerpoint
PLA for 180-210 C
gr5 2,210
This is a common problem. The set screws inside the pulleys are not tight enough. Tighten the hell out of them. All 11. If you only found 8 you didn't tighten the most likely culprits - those on the motors and short belts.
