@kmanstudios Thank you for sharing your experiences, and summing it all up.
I'd like to make a few additions:
* I don't think that it is necessary to clean out a well maintained BB core before storing it. I say "well maintained", because maybe in your case, the thing was already almost clogged when you put it away. I think even in the case the PVA in the core gets moist, the printer will push that out during the next time it primes. Absorbing moisture only makes the filament soft, which is an entirely different thing than (thermal) degradation. Of course I'm not saying that cleaning it before storage is a bad thing, but I think it is not worth the trouble.
* We have done a large test with 22 printers for more than 2000h. All with different preventive maintenance intervals. Our conclusion (yet to be published, so consider this a preview): the advised cleaning interval is 400h. Reason: during normal use, there is some build-up of degraded PVA on the inner sides of the nozzle. Even the printers which we gave *no* preventive maintenance stayed open, but the build-up will increase the chances of clogging when you have an incident, and probably the flow resistance increases as well, though this was not measured. This research concluded 400h was the optimal interval.
* Just by trying, we found that for some reason, clear PolyCarbonate (PC) works very well for cleaning the BB core. In many cases, the brown build-up is extruded when PC is pushed through the nozzle, while PLA is just extruded and leaves the brown stuff behind. Hot pulls at 270degC, cold pull at 135degC.
* Last but not least a remark about hot pulls: timing is of the essence. To be able to "fish out" the clog or dirt, you need to press the filament in the print core not too long and not too short. Too long will melt too much of your stick, and all the molten stuff stays inside including the dirt. Too short, and your stick has not become soft and sticky enough. You will learn by doing, but 1-2secs covers it I think.
kmanstudios 1,120
That is a great addition of information. But as I refine my process, I am going to be doing a bit more preventive cleaning, and as you suggested, I will also clean cores before storing, even for a short time. I had only been printing for two days with the dual PLA in AA Cores. I guess that was enough time to FUBAR the core into not working at all upon restarting. And, with gr5's input on a previous pic, I can now see that it was clogging up while in use.
But, yeah, the not cleaning before storing did make it fail. Working great now thanks to all the input from youse guys![:)](//content.invisioncic.com/ultimake/emoticons/5a33abdf6d109_1f60acopy.png)
