Thank you for your comment
the firmware is now updated. and the printer is 3 months old.
I have wiped the tip of the nozzle and done a manual leveling, and then a active leveling too. the active leveling keeps giving the same error message: Difference between detected height of both PrintCores exceeds realistic values. I don't know why.
In previous prints it doesn't look like there is curling.
I have seen in some other thread that a guy changed the BB nozzle and placed the AA nozzle instead, and the problem was fixed. then he changed back to the BB and he says it's working fine.
Some other people suggest to just turn the active leveling off...
kmanstudios 1,120
Leveling issue:
Do a manual leveling to get it aligned within tolerance:
https://ultimaker.com/en/resources/23127-build-plate-leveling
I usually do this and then do an active leveling because it is more accurate than I can do at this time. But it does require being close to level. Also, make sure your nozzles are cleaned and no material oozing out or collected around the opening causing a different measurement between nozzles. Both methods in link
Printhead colliding with models:
Print head can be hitting print if there is curling. Also, it looks as though your priming tower broke....it is prone to do that. Make sure you are on latest Cura and Firmware.
Cura
Firmware
I have moved further and further away from using the priming tower.
Different Materials will have different temps and fans and such, but the presets are very good to get you quickly in the ball park.
Edit: Oh yeah...also a good brim and adhesion method will help. Adhesion methods are things like Blue tape, BuildTak, PVA Glue slurry, hairspray, light salt water solution (research that because I am not familiar with its usage and materials to work with......I think it is geert_2 that uses that)
Edited by GuestLink to post
