No I don't think it is a skirt I am thinking of. That, I believe is attached to the model and help it to adhere to the print surface.
What I am looking for, my two test prints that came with the printer had a couple of passes around the edge of the model, but well separated from it.
It seemed to give the extrusion time to stabilize before it started on the actual model.
I could try using a skirt, but if that does not lay properly it might compromise the model to which it will attach.
Thanks
Nigel
gr5 1,872
I think what you call a "surround" cura calls a skirt. If I'm wrong then I need more info. Look at the skirt options in the basic settings.
