Liam 1 Posted June 23, 2017 in Extra Nozzle Space in UM2 Hello all, What if the hole for the extra nozzle in UM2 was removed, as there will be no dual extrusion? This would allow the fans to be closer to the nozzle and increase bridging and overhangs, especially on the right side. Also a lighter printhead could move faster. Just an idea. Cheers Share this post Link to post Share on other sites
ultiarjan 1,076 Posted June 23, 2017 in Extra Nozzle Space in UM2 You are right, but not sure it's worth the trouble, though you may be able to shave some weight of the main metal parts. To get the more even fan flow the solution is already here, my advice, print it in green-tec; https://www.youmagine.com/designs/um2-dual-fan-shroud https://extrudr.eu/collections/bdp/green-tec Share this post Link to post Share on other sites
Liam 1 Posted July 29, 2017 in Extra Nozzle Space in UM2 (edited) Makes sense. The green-tec has enough stability under high temperatures to not warp as a fan shroud? Would it be worth milling it from aluminium? What about making a carbon fiber fan shroud? Edited July 29, 2017 by Guest Share this post Link to post Share on other sites
ultiarjan 1,076 Posted July 30, 2017 in Extra Nozzle Space in UM2 Its all possible.... But the greentec works for me.... No deformations. Share this post Link to post Share on other sites
RudydG 28 Posted July 30, 2017 in Extra Nozzle Space in UM2 The greentec is a very good filament!! Make sure you have a good first layer and 60 degrees printbed, and the rest is easy. Very high temp resistant. Share this post Link to post Share on other sites
Liam 1 Posted July 30, 2017 in Extra Nozzle Space in UM2 Cool. Thank you!! Share this post Link to post Share on other sites
neotko 1,354 Posted July 30, 2017 in Extra Nozzle Space in UM2 Cool. Thank you!! For a fancap, even if it resists 100C try to cover the hottest areas with hihgemp aluminium tape. It will give you much more months of use, specially to avoid deformation due fan weight or high speed moves. A 150C alu tape is cheap and works fantastically. For Pla-tec bed temp is 55C. For greentec is important to use hairspray to avoid adhesion issues. pla and greentec are almost the same but platec is slightly more rigid and greentec is slightly more flexible. Share this post Link to post Share on other sites
