Siebet, thanks!
1
Apologies for the confusion. Siebet is right, no spacer there, my bad. I didn't pay attention to where the picture was taken.
1
Siebet, thanks!
Siebet 27
On that pulley there is no black spacer. Are the pulleys on that rod fixed? If the dubble pulley isn't fixed, you can push the pulley to the frame and screw up the screws...
Now the rod must be fixed and he isn't be able move anymore.
IRobertI 521
Have you looked inside the printer for the spacer? Since the rod got loose there's a good chance the spacer fell off and is hiding in the printer somewhere. It is _very_ unlikely it got out of the factory without the spacer, almost impossible I would say.
Turn the printer upside down and shake it a bit
This can happen if one or more of the set screws aren't tight enough on the rod to hold the pulley in place. Make sure you go through all the pulleys and tighten the set screw on each.
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#protrudingaxes
