My ten year old daughter helped me build my printer last year, and has been utterly fascinated by the entire 3D print process. She's learned her way around CAD and slicing tools, and the mechanics and operation of the printer, loading filament, etc and can quite happily design and print her own things now. I think it's a fabulous, hands-on way to get kids - especially girls, perhaps - interested in engineering and technology.
The printer is pretty robust, but as Daid said, it will need someone to take ownership of it and understand it, and be able to carry out basic maintenance to keep it running smoothly, and advise others on how to get the best possible results.
Another thing to consider is that 3D printers aren't particularly fast - prints typically take from half-an-hour for small things up to ten hours or more for larger or more complicated things. Therefore, you'll need to think about how it will be used, and when, because you'll only be able to print a limited amount of things on any given day.
Daid 303
The Ultimaker software (Cura) is very easy to setup and use. You can try this already, Cura can be found under "Community -> downloads", it's free and you can install it on as many computers as you want.
The machine itself will require some care and handling, but it's very robust. I personally have no issue with kids using my machine for example. You do need someone who is dedicated enough to play with it and understand it (as with any machine)
