currently the stream is served by mjpg-streamer so you should be able to use a variation on this guide: https://learn.adafruit.com/wireless-security-camera-arduino-yun/stream-video-to-youtube
You will need to create a port forward if you are behind a firewall or NAT, just google NAPT (network address port translation) and know that you need to direct that to your printer's ip on port 8080
Also note that mjpeg-streamer is quite possibly insecure so expose it to the internet at your risk!
neotko 1,418
VLC can get the image stream. I suppose from there you could do something?
@tinkergnome did test it, I never did but should be easy
https://ultimaker.com/en/community/23282-questions-about-ultimaker-3#reply-160603
