printer fails midprint due to filament "knots"
Schoepsi
Posted · printer fails midprint due to filament "knots"
Hey guys.
Lately my prints are failing due to this annoying error and I cant figure out what causes it. Since it didnt happen before Cura 2.6.1 the only guess I can make its anything software sided. I know, it sounds weird that an error like that has something to do with a slicer, but I´m thinking of any retraction settings that changed or something like that. Something that makes the spool lose its tension for a second and cause this "knot"
This error not only occurs on this cheap ass PLA, it also happens on my expensive ones like colorfabb, which u probably know is perfectly coiled up on spool.
From the last 4 prints (between 11h and 32h printtime), 3 failed cause of this error.
Has anyone of you guys an idea on how to solve this problem?
    This is not a software thing. This usually happens if you aren't careful when removing and storing a spool you've already used. It's very easy to have the end of the filament go underneath a coil on the spool and then you have this issue. You might not notice it as first since the filament can keep unspooling normally for a while but eventually it gets too tight and gets stuck. Only way to fix it is to uncoil the filament a bit and find the point where it crosses over and clear it.
    I´m usually very careful when removing a spool. I´m always making sure that the coil stays tight and use clips so it can´t unwind while stored.
    Also, the white spool u r seeing on the foto made a 20hours print before, wasn´t removed and remained untouched until I started a new 11hour print today, which failed after about 5 hours. It´s even funnier that this cheap ass white PLA runs more smooth than the colorfabb one. On my 32hours print with colorfabb I had to jump up every 30minutes cause I was hearing it getting stuck. Sometimes the motors had enough force to unstuck it on their own, but at some point it failed.
    here´s a photo of the colorfabb spool. at least optically everything seems fine to me
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 12 replies
