I will try to look all settings but the first weird thing I see is the infill overlap at 50%. Is way too high. A 15% should suffice and a 25 if you look for good looking stuff (without too much infill so it doesn't overdrip.
Also about the underextrusion. Higher than 0.1 means more mm3, if you never changed the TFM coupler, please check how many print hours since at 500-2500h it use to need a replacement.
Also to just remove your s3d settings out of the equation. Try Cura default settings for normal/fast settings. Just to have an example that more users can check or compare.
Is this what you were referring to? I have also posted an image of my run time stats, I didn't realize this was a wear item that needed replaced. I will try to make a test print tomorrow in Cura for comparison.
neotko 1,415
