I was working with another user some months back with a similar issue on a purchased model with zero-thickness walls. He found the following allowed it to be sliced, but I did not hear if it actually printed correctly:
- Uncheck all options under "Mesh Fixes"
- Set Merged Meshes Overlap to zero (0)
Maybe that will work for you.
Yes!, that did the work, now Cura finally shows inner ribs when sliced.
Now off to test 3D Print!
Thank you!
Just to report feedback.
It worked!
Now only to resolve stringing and it will fly to the sky
Awesome!
Happy Flying!!!
IRobertI 521
Cura is probably getting very confused about the zero thickness wall. Check the xray view and I'm betting you'll see a lot of red problem areas.
The model should be a proper manifold solid, not a surface body, to slice properly.
