windows 10
I am also running windows 10 with cura 2.6.2 installed and it will save to removable drive once and then if you want to do it again it will not recognize there is a removable drive available. Once you restart Cura it will again recognize the removable drive to save once. Any help would be appreciated.
Same problem here. with Win 7 and WIn 10.
always the second output to the sd-card fails (does nothing).
only switching to "save file" works or restarting cura. must be a sw-bug (came with 2.6.2).
nallath 1,104
Not unless we know what operating system you are using.
