Yes i did and it works, but i have to set everything on every print.
I'm looking for a possibility to set a gcode snippet and then only to say insert thins on layer 40, or layer XY ...
As example, i have a third fan and i want him to blow on layers with small details. So i want to tell simply: power on at layer X; power off at layer Y; on again on layer Z
I know i can do it with search and replace and i do it this way, but maybe there is a more simpler way.
DaHai8 74
You're trying the Search and Replace post-processing plugin?
If so, why is that not working for you?
