NOTHING IS WORKING"#!"!#¤!#¤
Preb1
Posted · NOTHING IS WORKING"#!"!#¤!#¤
The UM3 won't work with USB, neither connect via WiFi or LAN.. Every time I try to run wifi setup I get thrown back to the main menu. Same thing happens when I try to push print with usb..
Just bought the printer and it has been working for a while over wifi only, but I lost connection frequently during prints.. It has never worked via lan cable..
I tried to run a firmware update (stable version) and it only got worse, now it won't work at all..
please help?!
Log: https://pastebin.com/Rk0iGdz8
    Does it at least give you the menu system on the front panel? Or does it not even boot? If you have the menu system - put it into developer mode and then connect it to wired (I hate wireless in general) ethernet. The screen will tell you the printer's IP address within a few seconds after you connect the cable.
    However it sounds like maybe during the firmware upgrade it didn't do a full upgrade and now it's "bricked"? The only fix from that state (if that is the current state) is to take the bottom cover off and insert an SD card that already has the correct operating system software installed. then you turn on power and that will load in a new operating system. It can take 5 to 20 minutes depending on how fast the SD card is.
    Anyway you should contact your reseller as no one on the forum has posted a link to the iso file that needs to go onto the SD card. I have a proprietary one but you definitely don't want that version of the firmware.
    • 3 weeks later...
    Posted (edited) · NOTHING IS WORKING"#!"!#¤!#¤
    The machine fails to start because it has no MAC address programmed. That's also why the LAN connection failed.
    Please contact your reseller.
        • 4 replies
