tinkergnome 929
Did you get a "Z switch broken" (ER05) or "Z switch stuck" (ER06)?
Did you already made the tests, that are recommended on the error descriptions (https://ultimaker.com/en/resources/19488-z-switch-broken-or-z-switch-stuck or https://ultimaker.com/en/resources/23150-the-z-axis-is-stuck-or-the-limit-switch-is-broken)?
Have you recently disassembled anything on the printer? Do the motors move okay by hand?
If so, check if there are no pinched cables behind a cover or something along these lines.
The switches appear to function correctly (there is continuity between the appropriate pins when it's pushed or not).
Does that mean, that there's always continuity - regardless of the switch state?
fbrc8-erin 316
