You should be able to get a lot better results then that. Printing in that orientation I would lift the part a bit higher so the support can build a more sturdy base. Did you see how good the interface was as it was printing? What was the z offset?
Set the support z distance to 0.0 you want to print directly on the pva so it sticks to it.
kmanstudios 1,117
I am not sure what happened, but I would have printed it in the orientation of the actual printed object as you have it laying. In essence, flat parts down.
