There is a bit of an odd behaviour in Marlin where it sees a "M" as a "M0" (same for a "G" as a "G0") this might be your cause. Not sure how, but it might help a tiny bit, as Marlin is seeing an M somewhere.
Thanks for the replies guys.
After quite a lot of trial and error, then trawling through marlin code, then more trial and error, it seems it was caused somehow by the fact that I had the "watch" box ticked in pronterface. I have always done this before without problem, but somehow with my new prefix gcode I get the bug described above, every time.
Now that I am not "watching" with Pronterface, no problems.
I have exactly the same problem when printing from SD card when the doodle3d is connected. After heating the hotend it is always displaying "wait for user..." Seems the error is still there. The question is, is it the doodle3d or a bug in the marlin software that is triggered somehow. Given this post above it looks like it is a marlin issue when the temperature is monitored. Unfortunately I can't turn off the doodle temperature monitoring... (to my knowledge)
See also my post
http://umforum.ultimaker.com/index.php?/topic/10278-doodle3d-and-starting-a-print/
Ok I went into the code of Marlin and Daid was right, there is some weird behavior with the M0 and M1 commands. Actually they are not the cause but the commands that generate a wait for user message (actually the only ones if I am not mistaken). It is not in the M0,M1 commands but the handling of the M109 and M190 commands. Heated bed heating and extruder heating. I studied the main loop of the marlin code and during the M109,M190 calls the main tread is blocked by wait for the target temperature. This also means that the serial communication receive buffer is not emptied during that time. If there is a application requesting temperature status (M105 calls) these calls will not be executed untill heating is done. It means that the serial input buffer could overrun during that time causing miss interpretation of the received serial commands leading to strange behavior and in my case often M1 detection causing the user wait message. By studying the behavior of the Marlin (don't know if this is documented or where to look) I found that every serial command you give should be acknowledged with ok at which a new command can be transmitted. So the solution is that after heating you flush the receive serial buffer and then send the ok command. So this is my 1 line addition to the code of M109 (simular thing for M190):
LCD_MESSAGEPGM(MSG_HEATING_COMPLETE);
tarttime=millis();
previous_millis_cmd = millis();
MYSERIAL.flush(); // Eric remove received possible overflowing data
In my case this resolves the problem quite well. I can now print from wifi (doodle3d) and SD card while the doodle3d is connected. So how do I proceed to propose this change in the Marlin software?
gr5 1,872
I'm thinking the editor you are using is using multibyte character set.
Copy your gcode into the paste buffer, paste it into notepad, then save it from notepad. I don't think notepad supports multibyte characters hopefully.
What editor are you using? - most have the ability to convert to ascii 8 bit character set.
