Adding a custom printer .json to Cura
janajmfa
Posted · Adding a custom printer .json to Cura
Hello,
I'm trying to add my da vinci jr. 2.0 mix to the list of printers, but I can't get it to appear. Any ideas on what is causing the issue? Please note the formatting got messed up when I copied and pasted this over.
"id": "davinci_jr",
"version": 1,
"name": "Da Vinci Jr. Mix",
"inherits": "fdmprinter.json",,
"author": "Hacking Community",
"manufacturer": "XYZware",
"category": "Other",
"file_formats": "text/x-gcode;application/x-stl-ascii;application/x-stl-binary;application/x-wavefront-obj",
"platform": "davinci_jr_platform.stl"
"machine_settings": {
"machine_width": { "default": 150 },
"machine_depth": { "default": 150 },
"machine_height": { "default": 150 },
"machine_heated_bed": { "default": false },
"machine_center_is_zero": { "default": false },
"machine_extruder_trains":
"0": "custom_extruder_1",
"1": "custom_extruder_2",
"machine_nozzle_size": { "default": 0.4 },
"machine_nozzle_gantry_distance": { "default": 55 },
"machine_nozzle_heat_up_speed": { "default": 2.0 },
"machine_nozzle_cool_down_speed": { "default": 2.0 },
"material_diameter": {"default_value": 1.75 },
"machine_extruder_count": { "default_value": 1 },
"machine_gcode_flavor": { "default_value": "RepRap (Marlin/Sprinter)"},
"machine_start_gcode": { "default_value": "G21 ; set units to millimeters\nM107\nG90 ; use absolute coordinates\nG92 E0\nM82 ; use absolute distances for extrusion\nG1 F900.000 E-4.00000\nG92 E0\nG1 Z0.350 F6000.000\nG1 X3.000 Y31.000\nG1 F900.000 E4.00000\nG1 X5.000 Y31.000 F300.000 E4.46245\nG1 X5.000 Y131.000 E27.58519\nG1 X3.000 Y131.000 E28.04765\nG1 X3.000 Y32.250 E50.88011\nG1 F900.000 E46.88011\nG92 E0" },
"machine_end_gcode": { "default_value": "G92 E0\nM84" },
"machine_head_polygon": { "default_value": [
[-75, -18],
[-75, 35],
[18, 35],
[18, -18]
"overrides": {
"layer_height": { "default": 0.2 },
"layer_height_0": { "default": 0.425, "visible": true },
"wall_line_count": { "default": 2, "visible": true },
"top_layers": { "default": 4, "visible": true },
"bottom_layers": { "default": 4, "visible": true },
"material_print_temperature": { "visible": true },
"material_bed_temperature": { "visible": true },
"material_diameter": { "default": 2.85, "visible": true },
"material_flow": { "visible": true },
"retraction_hop": { "default": 0.2 },
"speed_print": { "default": 50.0 },
"speed_wall": { "default": 30.0 },
"speed_wall_0": { "default": 30.0 },
"speed_wall_x": { "default": 30.0 },
"speed_topbottom": { "default": 50.0 },
"speed_support": { "default": 50.0 },
"speed_travel": { "default": 120.0 },
"speed_layer_0": { "default": 20.0 },
"skirt_speed": { "default": 15.0 },
"speed_slowdown_layers": { "default": 4 },
"infill_sparse_density": { "default": 20.0 },
"cool_fan_speed_min": { "default": 5.0 },
"cool_fan_speed_max": { "default": 75.0 },
"cool_fan_full_layer": { "default": 4, "visible": true },
"cool_min_layer_time": { "default": 5.0 },
"cool_min_layer_time_fan_speed_max": { "default": 15.0 },
"support_type": { "default": "None" },
"support_angle": { "default": 45.0, "visible": true },
"support_xy_distance": { "default": 1 },
"support_z_distance": { "default": 0.2 },
"support_top_distance": { "default": 0.2 },
"support_bottom_distance": { "default": 0.24 },
"support_pattern": { "default": "Lines" },
"support_infill_rate": { "default": 15, "visible": true },
"adhesion_type": { "default": "None" },
"skirt_minimal_length": { "default": 100.0 },
"raft_base_line_spacing": { "default": 2.0 },
"raft_base_thickness": { "default": 0.3 },
"raft_base_line_width": { "default": 2.0 },
"raft_base_speed": { "default": 15.0 },
"raft_interface_thickness": { "default": 0.24 },
"raft_interface_line_width": { "default": 0.6 },
"raft_airgap": { "default": 0.2 },
"raft_surface_layers": { "default": 2 }
    First thing I see is two commas (,,) after "inherits": "fdmprinter.json",,
    However, json files are very strict on format, structure and indentation, so there could be issues there that can't be detected in your copy/paste.
    Use the code tags, > to place your json code in to retain the formatting, spacing and indentation. I will help a lot.
    It'll also get rid of those emoticons...
    Thanks for the replies, I fixed it up to a point and then ran into a code blocker that I don't understand using the validation website: https://jsonlint.com/
    Error: Parse error on line 210:
    ...default": 2 } }
    Expecting '}', ',', got 'EOF'
    "id": "davinci_jr",
    "version": 1,
    "platform": "davinci_jr_platform.stl",
    	"machine_width": {
    		"default": 150
    	"machine_depth": {
    		"default": 150
    	"machine_height": {
    		"default": 150
    		"default": false
    		"default": false
    	"machine_extruder_trains": {
    		"default": 0.4
    		"default": 55
    		"default": 2.0
    		"default": 2.0
    		"default_value": 1
    		"default_value": [
    			[-75, -18],
    			[-75, 35],
    			[18, 35],
    			[18, -18]
    	"overrides": {
    		"layer_height": {
    			"default": 0.2
    		"layer_height_0": {
    			"default": 0.425,
    			"visible": true
    			"default": 2,
    			"visible": true
    		"top_layers": {
    			"default": 4,
    			"visible": true
    		"bottom_layers": {
    			"default": 4,
    			"visible": true
    			"visible": true
    			"visible": true
    			"default": 2.85,
    			"visible": true
    		"material_flow": {
    			"visible": true
    		"retraction_hop": {
    			"default": 0.2
    		"speed_print": {
    			"default": 50.0
    		"speed_wall": {
    			"default": 30.0
    		"speed_wall_0": {
    			"default": 30.0
    		"speed_wall_x": {
    			"default": 30.0
    			"default": 50.0
    		"speed_support": {
    			"default": 50.0
    		"speed_travel": {
    			"default": 120.0
    		"speed_layer_0": {
    			"default": 20.0
    		"skirt_speed": {
    			"default": 15.0
    			"default": 4
    			"default": 20.0
    			"default": 5.0
    			"default": 75.0
    			"default": 4,
    			"visible": true
    			"default": 5.0
    			"default": 15.0
    		"support_type": {
    			"default": "None"
    		"support_angle": {
    			"default": 45.0,
    			"visible": true
    			"default": 1
    			"default": 0.2
    			"default": 0.2
    			"default": 0.24
    			"default": "Lines"
    			"default": 15,
    			"visible": true
    		"adhesion_type": {
    			"default": "None"
    			"default": 100.0
    			"default": 2.0
    			"default": 0.3
    			"default": 2.0
    			"default": 15.0
    			"default": 0.24
    			"default": 0.6
    		"raft_airgap": {
    			"default": 0.2
    			"default": 2
    Usually means you need another closing curly brace } somewhere in the json - either at the end or further up. I think its your "overrides" group that is not closed at the end.
    Thank you, turns out I needed a couple more. So now my json checks out, but unfortunately I still don't see it listed under "Add Printer" :( Are there any other reasons besides issues with the json that would prevent the printer from showing?
    Instead of pasting the json here, which consistently screws up the file beyond our being able to properly check it, could you post it on pastebin.com and post a link here?
    Here's the pastebin:
    https://pastebin.com/Yrt53whT
    Your definition file is in the format of Cura 2.1. It lacks a metadata section, and from Cura 2.3 on there is no "machine_settings" section but only a "overrides" section. Please have a look at the definitions that are currently in the resources/definitions folder.
    The CuraProfileMaker should be updated, or the reference to it should be removed.
    A lot of the profiles are in that format. For example the Lulzbot Taz 6, and it shows up just fine. I don't understand why one definition would work in the older format, but another won't.
    There is no Lulzbot Taz 6 definition in Cura 2.x (unless you are running the alpha build of the Lulzbot Edition of Cura 2, in which case please ask them for support). These are are definitions that come with Cura 2.7:
    https://github.com/Ultimaker/Cura/tree/master/resources/definitions
    What version of Cura are you using?
    I'm using Cura 2.6.2. I guess I can update to Cura 2.7 then update the .json file and see if I have any luck with that.
    So it turns out that updating to Cura 2.7 and then updating my .json file to reflect the 2.7 changes worked. I was able to get Cura to recognize not only my printer but the extruders as well. Thanks for all your help!
    Validate your JSON with json formatter
    Sometimes it's easier to validate the syntax with JSON lint first json new
