Posted · What is this material ?
Hi guys.
I was looking at a foot socket that was printed with a FDM printer recently.
The guys told me that the material was not ABS and PLA but was very sturdy and also a normal FDM printer material that is only available in black.
Here is a photo.
What do you guys think this could be ? Id like to know as Id like to try and print something similiar with my ultimaker 3.
The material needs to be good with shock and also a little bit of flex.
Any ideas what this stuff is ?
Thanks guys.
Ian :)
    Hi Ian,
    Dunno what that particular material is, but Nylon is strong and flexible maybe that would do? Ultimaker Nylon prints quite nicely with the Ultimaker 3 and you can use PVA as support with it.
    OK thank you.
    Little question or 2 actually.
    Is Nylon only available in black ?
    and is it a problem if the Nylon piece gets wet or is exposed to moisture for long periods of time. Would it become swollen ? or soft ?
    Thank you.
    Ian
    Posted (edited) · What is this material ?
    Nylon comes in transparent and black.
    It is effected by moisture and does swell a bit.
    This could also be polycarbonate which has a bit of flex. Tolerant to impacts and not effected by moisture the same but also comes in transparent and black.
    Thank you.
    I think this maybe is the better option than Nylon.
    Im always worried about parts losing their form and rigidity after being exposed to a lot of moisture and water.
    Thanks for your help guys.
    Ian :)
    I don't associate PC with 'a bit of flex'.
    I think PC is the stiffest material in the UM range.
    You can visit the Ultimaker website to find quite some information on our range of materials.
    If it's a full size (human size) built in 1 piece then most likely it's PC-ABS from Stratasys (it only comes in black ) or Ultem 9085 (PEI/PC) which come in natural tan or black.
