If you have a UMO with a LCD controller (ulticontroller) you can likely change the steps/mm for the z-axis to half its current value directly on the machine and store the new value in memory.
If not you have to configure and build a new marlin and upload it to your board ... Take care with this operation, as the one that is on the machine currently will be forever lost and your new build may have various settings that deviate from the ones you currently have.
gr5 2,225
lol. Well a quick hack is to scale up your models in 2X in the Z direction only (cura can do this if you unlock the axis) and then set flow to 50%.
What kind of printer do you have?
If it's a Ultimaker original these are both fantastic:
http://marlinbuilder.robotfuzz.com/
or
https://bultimaker.bulles.eu/
Basically you need to change steps/mm and double that value. If you have UM2 you can get tinkermarlin and adjust it right from the front panel.
First tell me your printer (it's okay if it's a prusa) and then I can tell you more details of how to build Mariln.
