SOLVEDNo retraction on travle inside the print (wall to wall)
gr5 2,189
If combing is disabled you don't get this (it retracts). I think you can disable combing on the first layer only in cura 2.*
Anyway turn off combing whether you use cura 15.* or 2.*
Evil128 0
Thanks a lot I will try this straight away.
Edit: It worked perfectly, thanks a lot for the quick help!
Edited by GuestLink to post
